Modbus RTU Address
Hi everyone,
I'm working with modbus rtu and i need to set up a connection with a master.
In my specifications the master should read from my slave a certain PDU to be xxxx.
For example, PDU2000 should be 4600, Read Holding Register, U16
How can i convert this PDU2000 to an address register such as 40001?
Thanks everyone in advance.
(1,484 Views)
Always confusing, the DCS way of defining ModBus registers.
A notation like 40001 tells that you have to use function code 3 (or 4 in most cases) and read address 0.
So the first figure is the command code (Read Holding register) and the last part is the ModBus address but 1 higher as the real ModBus address.
Kees
(1,416 Views)
