Modbus RTU Slave
Hi, I'm doing my first project with Labview. I need a simple example in which the Labview project is the slave of the Modbus RTU communication. My custom board is the master. Thank you.
Message 1 of 8
(5,305 Views)
in the Modbus NI VIPM package there is an example :
Message 2 of 8
(5,273 Views)
It is a TCP example. I changed from New TCP Slave to New Serial Slave and completed the connections to this block. Are there other modifications that I need to do? Thanks
Message 3 of 8
(5,210 Views)
Or does anyone know if there is an example of Modbus Slave RTU?
I already have a project of a Master RTU software that I could use to test the Slave RTU.
Message 4 of 8
(5,169 Views)
Accepted by topic author V.Life
In the slave example, just replace 'Create TCP Slave' by 'Create Serial Slave' in the polymorphic selector.
You have now to set a few Serial options.
 Don't forget Unit ID (Serial adress).
Message 5 of 8
(5,131 Views)
Thanks. That's what I already did. The scope of the Slave RTU for my project is to receive write register command from the Master (and then save data on the Slave) and receive read register command from the Master (and then the Slave has to transmit to the Master the response message with the requested data). So many of the elements in the front panel are not necessary now.
When I execute the program I get the error 56 @RTU Data Unit.lvclass: Read ADU Packet.vi 5030001
Message 6 of 8
(5,117 Views)
I solved by making a new project from zero. Thanks
Message 7 of 8
(5,092 Views)
Could you able to share samples to how to make labview as modbus rtu serial slave, as one of my project is demanding. It will be helpful. thanks
Message 8 of 8
(1,677 Views)
