Modbus RTU labview communication issue
Hi Sir,
     I have some doubt in pulling out the data from the device and setting the data into the device, the value whatever i set in the controller takes as a floating point data what i mean is, for example if i set the value for 100 means it takes 10.0 and replying me process value(PV) back as a floating point (ex.33.0)in controller and here in the UI as a integer(ex.330).
Dinesh
Message 11 of 13
(1,508 Views)
@dineshmeena wrote:
Hi Sir,
Dinesh
This isn't actually floating point, this could be called "fixed point" (albeit decimal rather than binary), because the decimal point is always fixed at a specific location in the number. What is your doubt specifically? If you need to convert from a floating-point number in LabVIEW to this format, first multiply it by ten, then convert it to an integer. To do the opposite conversion, first convert the fixed-point integer value to a floating-point, then divide by 10.
Message 12 of 13
(1,503 Views)
Hello!
I have the same problem to connect the TAIE FY400 with RS 485. So, can you send me your VI file?
Message 13 of 13
(1,461 Views)
