Modbus TCP/IP communication between LabView and YASKAWA P7 VFD
Does any body know how to connect Modbus  TCP/IP  between LabView and YASKAWA P7 VFD. Since I am new in using it I would appreciate any help. Attached is what I have done till now and a pdf file from Yaskawa, but I still have problems in reading values.
Sahand
(3,500 Views)
You will definitely need the Modbus Library to start. Beyond that, what other problems are you having?
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,483 Views)
