Modbus TCP/IP
I'm going to create a LabView project, in order to connect with a PLC S7-1500 via Modbus TCP/IP.
The problem is: In TIA Portal, I found a function named "Modbus TCP Client" for S7-1500. However, in NI LabView, while I use Modbus Library, I can choose between Modbus TCP Master and Modbus TCP Slave.
1) When do I call it Modbus TCP Master/Slave and when to call it Modbus TCP Server/Client?
2) So because the S7-1500 is a Modbus TCP Client, my Labview project has to be a Modbus TCP Server, right? Then how should I config it? A Master or a Slave?
I followed this sample in NI forum: Modbus TCP Sample
Thank you
(3,867 Views)
Typically Master=Server.   Slave=Client.
Master=Client. Slave=Server  (Thanks to drjdpowell correcting me.)
Devices tend to be slaves.
So your PC should probably be a master.
But that would mean your PC is a Client of the device which is "serving" up the data.
(3,850 Views)
Master/Slave is terminology from Modbus Serial or RTU, not TCP.  TCP is Client/Server.  Your device would be a "Slave" if Modbus serial, or a "Server" if Modbus TCP.
(3,832 Views)
Hi RavensFan. Actually the code for device (S7-1500) has been written already, and it config the device as a client. Also, my purpose is to read and write data between device and PC, so is it possible to config PC as Modbus TCP Slave to match my requirement? Thank you
(3,813 Views)
Hi drjdpowell. I have a further question as I reply to Ravens lFan. Can you take a look? I also find on the Internet that Master/Slave is only used for Modbus RTU. However, in NI Labview Modbus Library, it show 2 options for Modbus TCP as Master and Slave, that's why I'm confused
(3,809 Views)
I don't know what you mean by "TIA portal",  nor what "code for device is already written".  Is that LabVIEW code?
Yes, you can make your PC a slave.  That means the other device is the master and will send queries to the PC to get the data.
There are examples in the modbus library for a slave.  Generally that means that the LabVIEW code is running and waiting for a connecting from the remote master looking for commands.
Though I've played with making a PC the slave device before (mostly to simulate a slave I didn't have on hand), the vast majority of my work the PC is the master querying the remote slave device for data.  And the majority has been RS-485 serial RTU, not TCP/IP.
(3,806 Views)
