Modbus TCP Slave Configuration using I/O Server
I have a Labview 2020 Project that connects to an external PLC over Modbus TCP.  I set up the communication using an I/O Server.  The modbus communication works great when I am on the development PC, running in either development mode or as an executable.  However, the Modbus communication portion doesn't work at all when I try to run this executable on the deployment computer with Labview 2020 SP1 Runtime.
I am did read that the Modbus I/O Server does require either the Labview DSC module, or the Labview Real-Time Module.  I only have the Labview Real-Time Module as part of the "Embedded Control and Monitoring Software Suite".
Should this work?  Is there another Runtime or Driver that I need to install?
I hope I have attached the right files to allow you to see my I/O server setup.
Thank you
-John
(3,573 Views)
Yes it should work.  Here're some useful links that can help.
Creating Modbus I/O Servers
Configure Modbus I/O Server Dialog Box
Troubleshooting Modbus I/O Servers
And could You please say are there any error pop-up windows when You're trying to run this executable on the deployment computer?
(3,516 Views)
Thank you for your reply.  I used those links when creating my I/O server.  Sadly there isn't anything there that would help resolve my issue.  There are no error pop-ups when i am running this executable on the deployment computer.
I have contacted NI directly last week and put in a ticket.  The support person is able to recreate my problem but is still trying to figure out why this is happening.
I will keep you guys posted here with how this gets resolved so it can help someone else out in the future.
(3,499 Views)
Some suggestions if you haven't already tried them:
-create an installer from the source project and let LabVIEW automatically determine which components should be installed on the deployment computer, run that installer there
-on the exe build specification, review the shared variable deployment settings used for runtime, there may be something there that isn't set correctly
-NI Distributed System Manager may be useful to help with troubleshooting (gives some visibility to what NI's Shared Variable Engine is doing)
-The Shared Variable Engine system service may need specific Windows user login credentials
-Run things as Administrator
-scrap I/O server route and use one of the other options:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019?profile.language=e...
(3,490 Views)
Thank you playerm1 for your reply.
I have tried everything that you listed with the NI support tech.
I rewrote the code using the modbus library instead of the I/O Server.  It works great this way.
I am still hoping for a resolution on this issue so I can understand what is going on.
Thank you guys for the support.
-John
(3,488 Views)
