Showing results forĀ
Search instead forĀ
Did you mean:Ā
Modbus code for Power meter not working
In message #27, either the top or middle version should be Most Significant Word first.  The bottom one would be Least Significant Word First.  (If that doesn't work, maybe I mixed them up so try the other way.)
If you use Modscan64, do the values it shows make sense?
Message 31 of 57
(2,969 Views)
Yes, the values make very good sense and almost same as measured values. so is there anything I need to do or do you want me to send you a version of the VI for editting?
Message 32 of 57
(2,966 Views)
Then try implementing one of the methods I showed.  If you are still stuck, then attach the VI.
Message 33 of 57
(2,964 Views)
Attach is the Vi. please do make changes to the Vi.
Message 34 of 57
(2,954 Views)
Please do a Save for Previous version and make it LV 2015.  I don't have 16 installed.
Message 35 of 57
(2,950 Views)
Please see attached.
Message 36 of 57
(2,947 Views)
Try it again, the attachment is missing.
Message 37 of 57
(2,944 Views)
Message 38 of 57
(2,936 Views)
I'm surprised you weren't able to make the modifications I pointed out in previous messages.  Especially simple ones I talked about like creating the cluster constant and getting rid of the bundle.
Attached is a modified version.  In case you read multiple parameters and not just two, I used a typecase that took a U16 array to an array of singles.  That way you can take 2, 4, 6 registers and turn it into an array of 1, 2, or 3 Singles.
Message 39 of 57
(2,933 Views)
Thanks. I did the modifications you mentioned in another Vi that I saved in my computer and it never worked, so that was why I had to send you the initial VI for any needed Modifications. I will run this test on Monday and then get back with you on the result. Thanks for all the help.
Message 40 of 57
(2,926 Views)
