Modbus communication with PXI RT 8840
Hi all,
I have a third party hardware ( RS 485 ) that will read the temperature from the field. So from the Host PC, I am using the RS 485 to RS 232 converter and reading the temperatures ( Modbus )  . No issues in this. I am also having the PXI 8840 controller ( RT )  and PXI 1071 chassis. In the 8840 Controller, I am having the RS 232 port. so what were the steps to read a temperature ( Modbus ) through this (8840) ? ?
(3,313 Views)
Hi willcan,
connect your RS485-to-232 converter to the RS232 port of your PXI-RT card.
Then use the same VIs with the serial port of the PXI-RT instead of the host PC port - ofcourse running the VIs in the RT target…
(3,290 Views)
Hi gerdw ,
Already i tried that and failed. The same program when I run from the host PC means I am getting output. That's why I posted here
(3,282 Views)
Hi willcan,
what about posting your VI (or a stripped-down version of it)?
(3,279 Views)
hi gerdw,
15.0 labview
(3,275 Views)
Ok.
And where's the VI?
(3,270 Views)
How does it fail?  Are you getting an error message?
(3,263 Views)
