Modbus module for lv8.0
I have to work with labview and modbus.
I wud like to know what are the additional things required to use modbus.
I am using labview 8.0.From where can i get appropriate modbus libraries.
I downloaded modbus 8.2...But was getting errors bse of the mismatch in labview version.
Pls let me knw what is frmn where i can download modbus library for labview 8.0
Thanks in advance
Message 1 of 8
(4,741 Views)
I think the following can help you
Message 2 of 8
(4,726 Views)
Did you see this webpage?  http://zone.ni.com/devzone/cda/epd/p/id/4756
The zip file appears to have a version in LabVIEW 7.1.
Message 3 of 8
(4,722 Views)
Thank u for the reply.
Ya , i saw that webpage..frm there only i downloaded the library,but there not for 8.0 version,so i downloaded 8.2,but cudnt as its later than my version.So cudnt use as gving me version compatibility errors
Thanks again
Message 4 of 8
(4,719 Views)
Accepted by topic author user_1
Did you download and look in the ni_modbus_1_2.zip?
There was a directory of 7.1 version files in there.  You will be able to open those in 8.0.
PS.  You may want to use the spell checker.  The proper spelling for "cudnt" is "couldn't."
Message Edited by Ravens Fan on 03-05-2009 12:12 AM
Message 5 of 8
(4,717 Views)
Ya..i was able to use 7.1 version and working fine.
Is there anyother specific requirements for working with modbus?
It was not because i dont knw the spelling of couldnt.I just made it shorten..And for communication it didnt make any bad effect as i could find the solution still.
But i never noticed the check spelling option here.Thank u for the info and feedback.
Thanks again...
Message 6 of 8
(4,697 Views)
Hi...
Need some more help...
I would like to know how do i get data from logger using modbus....
I am not familiar with modbus.
So pls gve some examples of communication with modbus.
Thanks again....
Message 7 of 8
(4,674 Views)
What 'logger'  are you using?? Modbus is a master/slave communication protocol. The master requests to either read or write data from the slave. The data could be discrete bits or blocks of 16 bit register values. read the protocol manuals here. http://www.modbus.org/specs.php There are many examples of modbus communications in these forums.
Message 8 of 8
(4,660 Views)
