Modbus tcp
hi, i have to read some registers from an instrument through tcp ip. I know  their modbus adresses and the ip adress of the instrument. I download modbus library and i see ethernet example master that should do to my case. I don't understand how to set the parameters.
(2,900 Views)
Perhaps you could indicate which parameters you are having trouble with. Are you using the example VI?
(2,856 Views)
