Modbus
How can I test the connection through Labview?
How do I read/write to the device through Labview?
Message 11 of 21
(2,305 Views)
Hi wakho,
Send a command and read the device answer. When there is a (correct) answer the communication works…
NI ModBus library comes with example VIs. Start using the "Serial Master" example - and read the device manual to know about the allowed commands…
Message 12 of 21
(2,299 Views)
How do I send a command and read the device answer? (forgive me I am new to both labview and modbus).
Message 13 of 21
(2,294 Views)
Why are you using the NI Distributed System Manager?  Are you reading your instrument across a network?  If not, please just use NI-MAX so there's no confusion about what info you're getting.  If you don't know MAX check the tutorials here:  http://www.ni.com/tutorial/5439/en/   It's a great tool to troubleshoot these kinds of problems.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 14 of 21
(2,272 Views)
Hi wakho,
see the example VIs that come with the NI Modbus installation…
Message 15 of 21
(2,285 Views)
Thank you, your comment was very helpful. So now I can write to the device, no problem. But when i read or query I get this timeout error... How can I resolve this issue?E1.PNG
Message 16 of 21
(2,270 Views)
Why are you sending an *IDN? command to a modbus device?  That command does not exist in the modbus protocol?
Message 17 of 21
(2,270 Views)
Hi wakho,
I really love it when people stick with their threads instead of starting multiple parallel discussions (for the same topic)!
(Yes, sarcasm…)
Message 18 of 21
(2,258 Views)
(Yes, sarcasm…)
Or send you PM's asking you how their hardware works.
Did you use the simple serial example I mentioned?  Did you look at the modbus code I mentioned?  Did you take the free training I linked to?  Did you read the hardware manual for the device you are using?
Message 19 of 21
(2,242 Views)
Message 20 of 21
(2,237 Views)
