Modbus
Does anyone already use Labview and the modbus from schneider?
Message 1 of 10
(6,308 Views)
Modbus is supported by NI's lookout protocol drivers and is accessible
over LV OPC client.
If you have an OPC driver from your device vendor, you can try access it
from LV, e.g. via DataSocket.
A lot of info search at zone.ni.com, keyword: OPC, LabVIEW.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
Message 2 of 10
(6,308 Views)
We have used modbus to drive Eurotherm and Systag hardware. If yuo have a
documented divice, it works fine.
For your information, (no need to make our mistakes again), there are two
modbus types:
modbus RTU, and
modbus ASCII
There are RTU drivers available in our online library (for free...). We also
have ASCII drivers, but it's not ours.
Wiebe Walstra.
AIR technical Automation
www.air.nl
"freenao" wrote in message
news:8t6hgm$189u$1@news5.isdnet.net...
Message 3 of 10
(6,308 Views)
I was only able to find one Modbus driver in your library , called
MBmaster.vi , is that the one ? It seems to have been developed by a third
party , is this the one that's not yours and which one did I miss?
AIR Tech. Autom. wrote in message
<972482953.27391.0.pluto.d4ee054f@news.demon.nl>...
>modbus types:
>modbus RTU, and
>modbus ASCII
also
>Regards,
>Wiebe Walstra.
>www.air.nl
>new
Message 6 of 10
(6,308 Views)
Can I find then modbus ASCII drivers?
"matt" wrote in message
news:l16K5.7411$PS5.65023@news3.mia...
> >modbus types:
> >modbus RTU, and
> >modbus ASCII
> also
> >Regards,
> >Wiebe Walstra.
> >www.air.nl
Message 8 of 10
(6,308 Views)
The driver was developed by our company. It is the RTU driver.
The ASCII driver is not ours, and is not available through our webpage.
There is more information on:
www.mooregoodideas.com/FAVIs/PLC.htm
although I could not find a ASCII modbus driver.
We've got the ASCII drivers via a posting on pica army:
http://labview.pica.army.mil
Hope this help...
Wiebe Walstra.
www.air.nl
news:8tbbdi$1b58$1@news5.isdnet.net...
> >modbus types:
> >modbus RTU, and
> >modbus ASCII
> also
> >Regards,
> >Wiebe Walstra.
> >www.air.nl
Message 9 of 10
(6,308 Views)
Use Lookout OPC Server with Labview or Bridgeview
"freenao" escribió en el mensaje
Message 4 of 10
(6,308 Views)
"ILDE" wrote in message
news:39f893c4_3@news.arrakis.es...
Message 7 of 10
(6,308 Views)
Message 5 of 10
(6,308 Views)
I have used Schneider I/O modules 16 In/Out on Ethernet and the Ethernet to
Modbus gateway.
Message 10 of 10
(6,308 Views)
