ModbusTCP I/O Server - What am I missing....
FYI: Total Newb
No Labview training (soon). No hardware to deploy to (cRIO will be the eventual target). In any case I wanted to at least get some comms working.
So I decided to try adding the Modbus I/O server to the 'My Computer' target in labview.
Specifically ModbusTCP...
Inverter:
ModbusTCP Slave (Server)
IP: 192.168.1.100
Subnet: 255.255.128.0
Write to inverter = holding registers 1-256 (MBTCP starting address = 400001)
Read from inverter = holding registers 257-512 (MBTCP starting address = 40257)
MyComputer:
ModbusTCP Master (Client)
IP: 192.168.11.199
Windows XP pro SP3
As I said, I added I/O Server to 'My Computer'. Left everything as default except: set from serial to Ethernet, and entered the IP address of the inverter. (which replies to pings from the pc). Next, I added some bound tags: two words, bit wise, into the inverter. 400001.1-16, and 400002.1-16. I dragged these into the block diagram, and made a toggle button to set 400001.1 and 400002.1. I configured the inverter appropriately and monitored the fieldbus inputs using the inverter software. I 'run' the VI continuous, and set a probe on my toggle switch, just to be sure it is changing state.
Inverter: Nothin'
So added some of the system variables for the I/O server. Update Rate, Update Now, Comm Fail, etc.. and created basic controls, to set or display these items as needed. Set update rate 1.0, .25, 2.0 etc...
Inverter: Nothin'
Next I opened Modbus Poll (Modbustools.com) and configured a Master (Client) and poked a 1 into 400001.
Inverter: There it is! - endianness is wrong, but I can fix that later.
So what am I doing wrong in Labview?
Where are the typical diagnostic things that Modbus spits out - the exception codes? Invalid address, Slave not found, unsupported function code, etc...?
Next, I installed labView on my home machine (Win 7 pro)...turns out I must install something else to get the Modbus I/O server working, so I will install NI-RIO, then real time then FPGA, (all the things I installed on my XP machine. And I will try again eliminating my XP machine as a culprit (although it works quite well with Modbuspoll).
Thanks in advance for any sage advice.
Edit: Is it possible that the I/O server tried to use my WiFi NIC instead of the RJ45 NIC? The inverter would be un reachable in that case. Will try again with WiFi disabled...
(2,658 Views)
Success. With integers anyway. Something about writing Booleans does not work. I can recall setting in our HMI software 'bit masked writes' that enabled them to write to certain slaves. In any case I can packup my bits before writing to inverter.
(2,650 Views)
