Model Interface Toolkit with LabVIEW 2022 Q3 compatibility
Hi.
I wonder what is the plan for Model Interface Toolkit compatibility. The latest versions available for download is 2020 32-bit, and 2021 64-bit. I have to run LabVIEW 32-bit due to sbRIO compatibility. Is just tried to upgrade from LV2020 SP1 to LV2022 Q3, and found that Model Interface Toolkit would not run with that version of LabVIEW.
Does this mean that as long as I have to run LabVIEW 32-bit and Model Interface Toolkit, LabVIEW 2020 SP1 is the latest version I am able to use? Is there any known workaround to this limitation?
As my company has started to roll out Windows 11 AFAIK LabVIEW 2022 is the first version that supports this windows version.
(2,623 Views)
I have a similar question: Is there a document in I can find the compatibility of this software? I suppose that if I am using LabVIEW 2021 32bits the Model Interface Toolkit version would be 2020 32bits.
(2,545 Views)
