09-17-2018 02:02 AM
Ok, still a bit weird, but as long as your happy, I'm happy.
09-29-2018 02:11 PM - edited 09-29-2018 02:29 PM
It's rather odd that no one has mentioned that the DLL should be linked to labviewv.lib from cintools directory in order to run correct version of LabVIEW Runtime when loaded. So check your project settings and make sure it has labviewv.lib (not labview.lib) in additional dependencies field (Linker -> Input tab if you're working in MS Visual Studio). For the details on the "labview.lib vs. labviewv.lib" subject see also this thread.
Oh, I just saw that you are attempting to call a LabVIEW-made DLL in Visual Basic. The words written above are valid when you're writing a DLL in some other IDE (C/C++, VB, Delphi etc.) and then trying to call it from LabVIEW. I also assumed that the CIN was written by you and you're able to alter its sources to link it against labviewv.lib. If you don't have access to the CIN sources then it's okay to replace it with some other codeblock as you already did.
10-01-2018 06:13 AM
That's only needed it the dll is going to do LabVIEW related things. Most dlls are in fact not linked to labviewv.lib.
Since the dll worked fine before, it seems a stretch that it's related.
10-01-2018 07:13 AM
Well dadreamer is partly right. The message about labview.lib not being called from a LabVIEW process is indeed caused by the load stub in the labview(v).lib link library that links any of the LabVIEW Manager functions to the correct LabVIEW kernel. This link library does late linking, meaning it only tries to resolve the manager call when it is first called rather than when the according DLL is loaded.
You need to add labview(v).lib to every Visual C DLL project that wants to call LabVIEW manager functions. Such DLLs however can only be called by a LabVIEW process as the stub in the labview(v).lib library will attempt to locate the current LabVIEW.exe process or lvrt.dll kernel to link to the according functions.
For LabVIEW created DLLs the DLL load routine should be actually instantiating a lvrt.dll context on loading, to which it later attempts to link the manager functions. For some reasons that instantiation of the lvrt.dll seems to fail so that when the actual LabVIEW function then is called and the late linking tries to resolve the manager functions to deal with LabVIEW datatypes, it can't find the according lvrt.dll and then shows this message.
Unfortunately I'm not intimate with LabVIEW created DLLs and can't say exactly how they get instantiated nor what they try to do on loading so I can't really be of much more help here. Something seems to have changed in respect to the previous created DLL. Could it be that you installed a service pack for the LabVIEW version in the meantime?
10-01-2018 07:21 AM
And of course, in stead of statically linking to the library, the dll can call those manager functions by dynamically linking (e.g. LoadLibrary, GetProcAddress).
10-01-2018 07:50 AM - edited 10-01-2018 07:54 AM
Which the labview.lib stub does. When you create a DLL and the according import library you can specify a flag to the Visual C linker that will instruct it to create the import library with the delay-linking functionality. https://msdn.microsoft.com/en-us/library/151kt790.aspx
NI uses its own load stub that does customized detection if it runs in the LabVIEW IDE (linking to labview.exe) or in the runtime environment (lvrt.dll or one of its variants) and then the C linker will create stubs for each exported function that does the necessary GetProcAddress() assembly call on first call. Once the function pointer is initialized the assembly stub will immediately jump to the target address in the function export table of the destination module.
It's in this NI load stub where the message is displayed about not being called from a LabVIEW process when the LoadLibrary() logic can't find either a LabVIEW.exe or lvrt.dll module already loaded into the process space. Chances that calling your own LoadLibrary() function to link to lvrt.dll would work if the load stub couldn't are probably pretty small, and you have the potential that it might try to link to the wrong runtime module than what the DLL load routine did instantiate if that load routine was successful.
10-01-2018 07:58 AM - edited 10-01-2018 08:00 AM
I've used dynamic linking to avoid linking to external libraries. It's sometimes easier, for instance when not using C\C++.
Anyway, the dll we're dealing with in this thread is created in LabVIEW. So I (still) don't think including any LabVIEW libraries is the problem\solution.
10-01-2018 11:30 AM
The root of evil here is CIN and the topic starter has stated about that already.
@randomguy77 wrote:
Edit: I removed the code interface node from the VI for calculating the count, and it is now working again. I'm guessing it just didn't link what was needed from that into the dll. I can do the rounding in the text code, so it isn't that important that I need it included in the VI.
I assume the CIN was compiled against some other version of LabVIEW than the one that's being used to build a DLL from the VI. That is why it creates a total mess when trying to call such DLL from another IDE as Visual Basic (which's used here). What is really happening is behind the scenes to me, but AFAIK all existing and existed CINs were linked to labview.lib and not labviewv.lib, so when the DLL got loaded and tries to load the CIN (which is also a DLL after all), it cannot find lvrt or main process and gets confused with that specific message. By the way Rolf has already dealt with the similar issue: Building a LabVIEW DLL with VIs that use CINs. There the thread's author just recompiled his CIN against the same LabVIEW version, where he was making a DLL, and it worked fine. Leaving aside the question of CINs' obsolescence, I'm curious if it will locate and link to the runtime correctly, when linked to labviewv.lib (never ever had created LabVIEW-built DLLs with CINs inside).
10-01-2018 04:28 PM - edited 10-01-2018 04:32 PM
As it hasn't really been possible to create CINs since about LabVIEW version 8.0 I generally just ignore mentioning of that in nowadays posts as most posters really mean Call Library Nodes anyways. But it could explain the problem indeed as an old CIN is not really prepared to deal with the situation where it is called from inside a LabVIEW generated DLL.
10-02-2018 01:20 PM - edited 10-02-2018 01:31 PM
Well, I just found the time and did quick tests with CIN inside LV-made DLL. I compiled a primitive CIN against LV 8.5 toolchain and made two DLLs in LV 8.5 and 2011 with it and tried to call both from Delphi. Everything works fine, even when it's linked to labview.lib (without "v" at the end). If I remove 2011 RTE, the DLL code shows a pop-up about RTE missing and terminates. If I remove 8.5 RTE, the CIN code launches an installer (!), which tries to reinstall RTE (sometimes even with success). So, it is (was) okay to place CINs into LV-made DLLs, at least those compiled with the recent toolchain (4).
I did a second look at that strange CIN by TC ("NEGTHRES" it's called) and found this. It appears to be a VERY old CIN (27-28 years old, huh?). The internal field states, it was made with toolchain 1. And it doesn't export SetLVRTModule but tries to determine all addresses inside GetLVSBHeader. That is why it doesn't work as should. It just checks for GetModuleHandle(NULL) and LVRTTable symbol, no checks for lvrt.dll at all. LabVIEWFL says it's done with WATCOM C, but I doubt - I don't see clean marks of it (MZ?). A lot of ancient code still refusing to stop its work by a miracle. ![]()
