Modify Plot Legend
I want to modify plot legend. There is alot of options to select when click on signals but I only want users could select Color part.
How could I make remove other options (common Plots, Line Style, etc...) from the Plot legend menu.
And How could I change the language of it like Color is Renk in Turkish and I want to show this part in Turkish.
Yasemin Barutçu
Electrical And Electronics Engineer
(3,711 Views)
You cannot modify those menus.
Disabling the runtime menu for the graph does not disable the legend runtime menu. You would need to create your own legend that has its own popups.
(3,697 Views)
If I couldnt change or disable these menus then  I have to change the language of this menu. How?
Yasemin Barutçu
(3,685 Views)
I may be mistaken, but as far as I know, there's no way for the end-user to change the language for those menus, so you would need to use the Turkish language version of LabVIEW.
(3,674 Views)
There isnt any.. So I couldn't do this. Thank you.
Yasemin Barutçu
(3,655 Views)
