Modify Template for Class Accessor vi
when I create an accessor VI, Labview changes the VI name to "ReadTemplate". Seems off to me.
Where is the template located? (Labview 2019 32b) and is it possible to change it?
(1,485 Views)
Hi LabviewBow,
the Labview Class Framework Library is located under
"C:\Program Files (x86)\National Instruments\LabVIEW 2019\resource\Framework\Providers\LVClassLibrary\NewAccessors"
search for the ReadTemplate.vit and WriteTemplate.vit templated and change check the checkbox you posted earlier.
Make sure to save it again as a template!
Hope this helps!
LabviewBow
(1,417 Views)
