Modify front panel properties from a text file
Good morning.
Maybe this question is already answered but I can't find it.
I'm trying to create a menu ring in the front panel which strings are taken from a text file, and i have no clue how to do it.
I have as input a file a text file with a list of positions, and with that file in the front panel i would like to show a menu ring with all the postions that are available. I suppose that it has to do something with the properties but I'm quite new in Labview so I don't know how to do it.
If someone could help me i'd appreciate it.
thank you very much
(2,892 Views)
Accepted by topic author José Alberto
Hi Jose,
Welcome to the world of LabVIEW!
It sounds like you need to learn some of the basics of file I/O and GUI customization.  You should probably start by learning the basics of LabVIEW using many of the tutorials, examples and online help that come with the product.  The following links will help you get started:
To change the properties of your menu ring:
Programmatically Edit Items in a Menu, Text, or Ring List
To read from a file:
Getting Started: Read Data from Spreadsheet (.csv) and Display in LabVIEW
http://www.medicollector.com
(2,885 Views)
thanks a lot.
it looks like i didnt pay too much attention to the examples, because i think i solved my problem!
next time i will try harder before posting a question
thanks for the links!
(2,879 Views)
