Modifying 'signal output range' for AO task from within LabView
Hi! I have configured a Tasks in MAX which is an analog output. I created a custom scale and set the signal output range from 0 to 250 RPM, per my scale. This works great.
My LV application allows the user to 'calibrate' his inverter, and the VI updates the custom scale based on the new fit. In some cases, the maximum range of the output could change based upon the new equation.
Is there a way to programmatically update the signal output range max for my task? I tried using a DAQmx Channel Propety Node and set the AO.Max - but I don't believe it is writing back to the MAX.
Any help? Thanks!
~Jayesh
(3,175 Views)
Hello Jayesh,
It looks like you are trying to accomplish several things. Here are some resources to assist you:
1) Creating Custom Scaling in LabVIEW
Programmatically Create a Custom Scale in DAQmx
2) Changing the maximum and minimum values of analog output
How To Change Min and Max Values For Data Acquisition Without Stopping the Program?
3) Programmatically changing task configurations in Measurement and Automation Explorer (MAX)
Discussion Forum: How to programmatically configure MAX?
For your application, you may want to consider why you need to make configuration changes in MAX. Can everything you need to do be done in LabVIEW?
  Sandra T.
Applications Engineer | National Instruments
(3,149 Views)
