Modular instruments not appearing in "create new" list of NI MAX
Hi all.
I want to use MAX to simulate daq usb 6009 without actually using hardware usb daq but when i try to create new device in MAX , i am not able to see "Simulate NI-DAQmx device or modular instrument" modular instruments in list of devices as shown in attached desired png, i have also attached the actual png that shows scenerio at my pc that  shows only NI-Daqmx simulated device not showing modular instruments as in desired png.
(4,274 Views)
Hi ibn-e-safi,
can't you simulate the USB6009 after selected the "NI-DAQmx simulated device" item?
(4,265 Views)
 no dear. i am not able to see the usb6009 in list as shown in attached photo
(4,217 Views)
Hi ibn-e-safi,
use a more recent LabVIEW/DAQmx version:
(Screenshot taken using LV2014SP1 with DAQmx14.2)
(4,214 Views)
Hello ibn-e-safi,
Well, Can you check your DAQmx version first?
USB DAQ modules are compatible with the following versions (or later) of NI application software: LabVIEW 7.x, LabWindows/CVI 7.x, or Measurement Studio 7.x. USB DAQ modules are also compatible with Visual Studio .NET, C/C++, and Visual Basic 6.0.
Try reinstalling your DAQmx driver (even try doing a force reinstall of the driver)
-Andrea G
Applications Engineer
(4,175 Views)
Accepted by ibn-e-safi
I download this version of DAQmx(shown in attached photo).
It is working fully and m enjoying Whole functionality of DAQmx.
Thanks God
(4,133 Views)
