Modulation toolkit dependenies problem
I have labview 2011 with modulation toolkit 4.3 along with NI-RFSA 2.4.5,NI-RFSG 1.7.2 and NIscope 3.8.5...I was trying to work with NI-5660 and when I wanted to use ni5660 initialize.vi... It asked to located some dependencies which I did not have.. I want to know that How can i solve these dependencies which drivers or toolkits do I need for these dependencies..
1. mod_SetRxIQdemodulator.vi
2. mod_get tnrSetAttenRef.vi
3. mod_Set RxDCAtten.vo
4. mod_Set RxRFSARefLevel.vi
5.mod_Get RxRFSARefLevel.vi
6. mod_Get RxType.vi
7. mod_Set RxType
8. mod_Set RxRFSAMixerLevel.vi
9. mod_Get RxRFSAMixerLevel.vi
10.MT configure Downconversion Settings(RFSA).vi
11.niTuner Set Attenuation.vi
(2,943 Views)
Hello Sabe, hope you are doing great!
Apparently what you are missing for you application is not a toolkit but the Instrument Drivers to talk to the RFSA.
You can get those driver here. Go ahead and select the product you are using and download the drivers. I will suggest to read the Readme file for instructions on how to install the drivers.
Alternatively you can look for drivers from LabVIEW, from the main screen under help, go to Find Instrument drivers. Follow the wizard, select the manufacturer and product.
Luis A.
Applications Engineer.
National Instruments.
(2,930 Views)
