Module reinstallation (specially for DSC)
How "A" module of Labview suite can be reinstalled using installation DVD? the normal setup apparently tries to install a new version or instance of labview?
( reason: DSC module seemed to be installed but seems reporting service of the sql and support file failed to install. Beleive fix the issue  with ISS so now want to reinstall the DSC module only, but then in the installation it askes to install the labview 2012 also)
Dave
(3,076 Views)
Hi Dave,
The installer allows you to select or deselect what you want to install, by default LabVIEW is selected but if you just want to install the DSC module deselect this and select the DSC module under the Industrial Monitoring category.
(3,000 Views)
Adam.
If I deselect Labview then DSC installation return an error that it needs labview option to be checked to proceed with re-install. Having the labview option checked in the installation, doesn't seems like to recognize an already installation, does it?
(2,986 Views)
Does it come up with an error or does the box have a "no" option? It will say you need LabVIEW installed as the module depends on it, but if you already have LabVIEW installed you can click "no" and continue with the installation.
If this doesn't work I would suggest a re-installation of LabVIEW as it sounds as if some components might not have installed correctly the first time.
(2,974 Views)
