Modus Ethernet communication problem
Hello!
I have a problem with NI Modbus Library.
When I was testing the modbus Ethernet examples from the NI MB llb I discovered one funny case...
It is working with ordinary Ethernet cable, but does not work properly if I use only 4 wires of the cable (1,2,3 and 6 wires).
I guess it should be enough to use 4 wires.
So, the problem: I use one Slave and several Masters and the ethernet cable category 7. If I use 4 wires of the cable then I can use only one Master.
But when I try to connect another one Master then the Slave buzz and does not answer. I can not understand it...
If somebody knows the problem, answer me, plz
(2,761 Views)
I have found the reason... The NI MB library does not work if PC has DNS address, but it connected to the local net without DNS server (i.e. without Internet)...
(2,706 Views)
