12-18-2018 01:54 PM
Has anyone created an FP On-Off-On momentary toggle switch (preferably horizontal)? I am testing a piece of equipment and need to indicate this action on the FP.
12-18-2018 02:35 PM
Just change the Mechanical Action of any switch to one of the latching types
12-18-2018 02:49 PM
I think the question is more complicated than this. It sounds like a 3 position switch, where you can click on the right or left, but then it snaps back to a center off position. This might require special graphics and programming to implement. Probably an enum rather than a boolean since it has 3 states (left on, right on, center off) rather than the normal 2 for a boolean (on or off, true or false.)
You'll probably need an event structure to handle it.
12-18-2018 02:51 PM - edited 12-18-2018 02:59 PM
You're right. I think I misread the question.
Try this thread
12-18-2018 03:03 PM
Thanks for the reply, I guess I wasn't specific. I know how to make a momentary switch. What I need is a three position toggle. Right-On right, middle Off, left-On left. The equivalent of an SPDT (Single-Pole, Double-Throw) switch in electronics. Where the right and left positions are momentary. That is the 'big' challenge. I would be satisfied at this point if I had a three-position toggle indicator with the same action. I have two BOOLEAN controls: right-on/off and left on/off that I need to have control a single three-position toggle indicator.
12-18-2018 03:23 PM - edited 12-18-2018 03:25 PM
That link Manchoo posted is excellent.
It is a combination of two switches, and they are grouped together to keep them attached.
All you need to do is change the mechanical action on the lower one. And change the pictures on both so they reflect a horizontal switch.
Oh, and change the output logic. This one ORs the two results to be a single Boolean.
12-18-2018 03:25 PM
How would you activate a three position toggle? IRL, you push it to the left or to the right and it snaps back. However in software, that's not really feasible to do unless you CTRL+click to go left and CLICK to go right (or some other modifier).
12-18-2018 03:26 PM
You click right side to go right. Click left side to go left. With the autosnap back, you the return to center is automatic.
12-18-2018 03:29 PM
Yeah I just saw the link. That's quite genius. Very nice, Altenbach.
12-18-2018 05:50 PM
If you just need an indicator, use a Picture Ring with a few carefully chosen images:
