Monday morning breakpoint problem
I have somehow ended up with a breakpoint on a case structure and I can't see how to get rid of it. The red box is on the inside of the case box. If I click on the box, it allows me to set a breakpoint, which then shows up on the outside of the box. I can clear that breakpoint, but the breakpoint on the inside of the box is still there. A breakpoint search just highlights the case box.
So is there a way to just clear all breakpoints, or at least just the mystery breakpoint that I have?
Thanks.
Chuck Gantz
(2,496 Views)
To get rid of the breakpoint in side the case structure select the set\clear breakpiont tool from the tool menu then click anwhere inside the Case structure.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,479 Views)
Thanks Andrew,
That solved my problem. I never noticed the breakpoint tool on the tools pallette. I kept looking in the tools menu, where, of course, it isn't.
Chuck Gantz
(2,465 Views)
