MongoDB GetCollectionNames
I am Using MongoDB in LabVIEW.
I am able to retrieve all the data from the Mongo Database.
But unable to retrieve the Collection/Column names from the database.
Error:
Property Node (Arg :1) Error accessing property System.Collections.IEnumerator.Current, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Inner Exception: System.InvalidOperationException: Enumeration has either not started or has already finished.) <append><b>System.InvalidOperationException</b> in code1.vi
For reference I am attaching the VI. Kindly Guide me on this.
Thank You.
(1,792 Views)
You should be using the output of MoveNext to determine whether there are any further items in the collection before attempting to retrieve an index (https://docs.microsoft.com/en-us/dotnet/api/system.collections.ienumerator.movenext?view=netframewor...).
In terms of debugging - check if there are any items in the backing collection (Count).
(1,724 Views)
The output of MoveNext is always 'False' even if there are collections in the database.
(1,702 Views)
