Monitor 1D Boolean 8Bit array for Changes
dear altenbach;
My real code uses a refnum to a 1D 8 bit boolean array. I need to monitor this array for a hcange in value. On a value change, I will need to execute a command. Let's call it IOChange.
Does this help? My spec does not say if I need to know which Boolean changed state but I am assuming so.
4BoysDad
Message 11 of 17
(1,610 Views)
Hi Again,
As you can probably tell, I am fairly new to LabVIEW. I do have my CLAD.
I attached an image in which I tried to replace your input switch array with my Boolen Refnum which LV does not like.
4BoysDad
Message 12 of 17
(1,606 Views)
Hi Again,
4BoysDad
Message 13 of 17
(1,606 Views)
Use the refnum with a value proprty node to ge the array.
Message 14 of 17
(1,599 Views)
Dear AltenBach;
What would the attached vi looked like if you used shift registers? I am only on my 2nd project.
4BoysDad
Message 15 of 17
(1,561 Views)
Right-click the current feedback node...replace with shift register. 😄
Message 16 of 17
(1,558 Views)
After I posted my question, I figured it out.
Thank you just the same. Smiley Very Happy
4BoysDad
Message 17 of 17
(1,546 Views)
