Monitor Files installed in system by installer
Hi all,
I  have one installer of my application built through LabVIEW. I need to monitor the files like *.dll and other files which are installed on the system.
Can we get a list of files installed by the installer on the system for monitoring purposes?
Thanks.
-Parag D
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 16
(5,302 Views)
Could anyone please let me know if this is possible in LabVIEW built Installer?
-FraggerFox!
Message 2 of 16
(5,267 Views)
Hey Parag,
I'm not sure if this is exaclty what you are looking for, but you could try Process Monitor. Its a utility by Microsoft which provides a lot of info about the programs running on
your PC. Maybe you will be able to get the details from there.
Message 3 of 16
(5,259 Views)
WellWell, Its like I need to see exactly which files are going where during installation. This feature is available in many installers showing path of files being installed (for eg. Winamp setup).
-FraggerFox!
Message 4 of 16
(5,255 Views)
Is there any other option available except process monitor? Process Monitor would just show the presently running background processes.
-FraggerFox!
Message 5 of 16
(5,224 Views)
I think I understood your query correctly.
It is not possible with the labVIEw installer. You need to write it of your own using Install Shield package or something like that...
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 16
(5,209 Views)
Hi Partha,
Can you please explain how to create a InstallShield package for LabVIEW Applications?
-FraggerFox!
Message 7 of 16
(5,200 Views)
Hi Parag,
See here.
Message 8 of 16
(5,196 Views)
Well, I believe that LabVIEW Application Installer cannot be created through Installshield. Pls correct me if I am wrong
-FraggerFox!
Message 9 of 16
(5,181 Views)
I am quite sure that Labview installer is based on Microsoft Installer (MSI)
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 10 of 16
(5,176 Views)
