Monitoring DC and AC simultaneously on same device but seperate channels
I am trying to get analog input from the same device at the same time but from different channels, I have created a .vi that works, but it gives me a AI Group Config warning, Is there a better way to do what I am trying to do?  I have attached my code, I am using v 7.1
(2,847 Views)
AI group config warning or ERROR? I get Error -10401, but that's because I've not setup the AI device in the Measurement and Automation Explorer (MAX).
(2,834 Views)
I get  warning 10803 AI Group Config
(2,819 Views)
Use one AI Waveform Scan. I don't understand how you are doing the channel specification for the one with multiple channels either. No need for separate array elements unless you want to use different ranges on each but you only have a single array element in the input limits. Use one channel array element and specify all channels in a single list.
(2,816 Views)
