Monitoring DTR RTS CTS
I'using Labview 5.1.1
I just want to monitor DTR RTS CTS states of my COM port.
I think it's basic, I know Google is my friend but i've spend too much
time trying tips that do not work.
What is the easiest way to perform the task according to you ?
thank you.
Rudy
(3,108 Views)
Are you using VISA or the older serial functions? With VISA, you can do it with a VISA property node (Modem Line Settings). In your old version of LabVIEW the property node may have been called something (attribute nodes?). The other serial driver has a function called serial line ctrl.vi and it's in vi.lib>platform>_sersup.llb.
(3,098 Views)
