Monitoring does not start
Thanks a lot RavensFan. I chose a timeout value of 0. My benchmark when run on an embedded system at higher frequencies can be over in under a second. So, I need millisecond resolution. It does not seem to take 0.01 and defaults to 0.
Now, I have analyzed it again. Looks like I am unable to hold the value "start" in the shift register in iterations after the first iteration. I am guessing that I need to hold that value inside the while loop. With an array?? Any suggestions?
Thank you very much for your time. Really appreciate it.
Message 11 of 12
(743 Views)
Hi JohnDoe,
Did you read the (extended) help for that UDP function and it's timeout input?
Do you know which values are expected as timeout?
RTFM…
Did you understand my pseudocode given before?
Do you have problems implementing simple IF-THEN statements with LabVIEW?
(Do you even read the suggestions you already got?)
Right now your shift-register is pure non-sense. All it does is delaying ("pipelining") the comparison by one iteration…
Message 12 of 12
(729 Views)
