More String Control Scrollbar Bugs
In the series of bugs that will never be fixed but need to be posted for the record, here is a variant of the String Control horizontal scrollbar topic.
Take a String Control (works with Classic, Modern and Silver):
Show its horizontal scrollbar. That's not an immediate process, so here is the wya it goes in LV 2013:
- Show Properties
- Go to the Appearance Tab
- Uncheck "Wrap at word breaks"
- Check "Show horizontal scrollbar"
Here's the result:
Where's the scrollbar?
You have to grab one of the control edges, expand it VERTICALLY by one pixel and the container box with then snap to a size that accounts for the scrollbar height:
Expanding HORIZONTALLY has no effect:
If you try that with the System String Control, similar limitations apply but you get a bonus:
The one pixel tall string!
Message 1 of 22
(6,557 Views)
Are you using LabVIEW 2013 SP1 or just 2013? I don't currently see any internal documentation of this, so I am going to recreate the situations using SP1.
I should be able to get back to you later today with more information and the next steps I will be taking.
Message 2 of 22
(6,506 Views)
2013 SP1 Windows XP 32bit
Message 3 of 22
(6,489 Views)
My guess is that the box just isn't big enough to show the scroll bar.  If you re-size the control vertically before you enable the scroll bar, it shows up just fine.
Bill
CLD
(Mid-Level minion.)
Message 4 of 22
(6,480 Views)
That is probably a good guess. However, I would argue that if I go throught the trouble of opening the Properties Panel to ask for a horizontal scrollbar, I'd be happy to get the scrollbar added.
I have actually found out another oddity (which makes the behavior of the System String somewhat less outlandish):
If you take the default Silver String control, which has a height of 37 pixels, and expands it to 39 pixels or more, then following the procedure I described in my original post, the horizontal scollbar will be shown.
Like this:
Here I have painted the String background in red so that you can see that a 1 or 2 pixel string display area is available (like I described for the System string, but here, if you further manipulate the control, it will snap to a more reasonable height allowing you to type in something visible).
So, what I am saying is that there is not much coherence in what the algorithm considers a valid condition to show a scrollbar. Of course all this becomes very interesting when the font size is changed...
Message 5 of 22
(6,462 Views)
Like this:
Well, you just illustrated exactly what I meant.  The scroll bar is as tall as the control itself is.  I think it is unavoidable though.  Just look at everything that has a scroll bar.  The scroll bar gets added to the INSIDE of the window that needs it, not the outside.
Bill
CLD
(Mid-Level minion.)
Message 6 of 22
(6,454 Views)
Indeed, and I said so.
However, I think I have also proven that this "internal" addition of a scrollbar concept hasn't been thought through by NI, since they seem to be shy to add one when there is 0-pixel space, but not when there is 1-pixel space (or 2, I am not sure).
What is the sense of this, for any one out there?
Disclaimer: I don't have a degree in CS, but I will call a cat a cat.
Message 7 of 22
(6,449 Views)
I think it is simply that there is not enough room to display the scrollbar.  Probably what needs to be done is either make the default size of the control a little taller or make the scrollbar a little shorter.
I didn't mean to imply that it was correct behavior.  It's just expected behavior.
Bill
CLD
(Mid-Level minion.)
Message 8 of 22
(6,443 Views)
I think you do have a bug here.
Even if you work with a Modern style string control, it is doing similar things.  And when it adds the scrollbar overtop of the existing single line string area, it doesn't look like a scrollbar, it looks like an empty string box that you can't type into when you try.
Message 9 of 22
(6,441 Views)
This got me curious about the vertical scrollbar behavior, and this is exactly similar:
ScreenHunter_003.jpg===>   after Properties>> Show vertical scrollbar  ====>ScreenHunter_004.jpg
Clearly not large enough to see a full character.
After blowing the Font Size (repeated Ctrl+=):
I have got a single character "c" in this string.
Message 10 of 22
(6,440 Views)
