More than 1 data source
I have for loop that is driven by the output of the VI.
lets say If i want to have more than 1 data source to be connected to the N of the for loop,,how can I do that..
I remember there used to be u shaped symbol to tie one end to two sources..
(2,788 Views)
You've already said you have a Select function so your question does not make any sense. You can only have one source. You really need to explain exactly what you want to do. Picture or an actual VI.
(2,779 Views)
