Morse Decoder Array Problem
I have trouble believing this code works.  You have an obvious race condition.  Use wires instead of your local variables.  Plus, try using a FOR loop instead of the while loop and indexing.  You can autoindex the incoming array.
Here's my refactoring of your code.  So much cleaner.
Message 11 of 12
(873 Views)
Not good.  Suppose you have a number combination that doesn't show up in your array.  The while loop will run for ever.
Use the Search 1-D array like it has been suggested.  Then if a number is not found, it returns a -1 as the index and you can handle that however you want to.
Message 12 of 12
(866 Views)
