Moteconfig over labview
Hi all,
I have a query, it might sound a bit strange but I would like to know that is there any way by which I could deploy an entire application say ( moteconfig) of crossbow on Labview and then work with the Moteconfig application from Labview ?
Any suggesstions would be helpful !
Regards
Anil
Message 1 of 8
(3,900 Views)
Hi Anil,
can you explain a bit more about what you want to do? Is the MoteConfig only an example for a big application or do you want to work with it?
Mike
Message 2 of 8
(3,887 Views)
Hi Mike,
I would like to deploy the entire moteconfig application inside labview. Is tht possible in labview ?
Message 3 of 8
(3,884 Views)
Hi Mike,
I would like to use all the features offered by Moteconfig using Labview by having an entire application deployed inside labview.
say for example, when I connect to labview, on the web interface of labview i see a moteconfig screen
Message 4 of 8
(3,883 Views)
Hi Anil,
i think it´s possible, but why? What about using MoteConfig from LabView?
Mike
Message 5 of 8
(3,880 Views)
Thanks for the prompt reply Mike, well I have already done the remote configuration of motes using moteview, now if labview can be integrated with moteview I could connect to labview via the internet and configure my motes ...
could you please let me knwo the steps which can be taken to make this possible
thanks
Message 6 of 8
(3,878 Views)
friends,
any luck !
Message 7 of 8
(3,862 Views)
Hi Anil,
I don't believe this is possible, given the way you've described it.  If Moteconfig has a command line interface, this can easily be used in LabVIEW.  If you want to serve the Moteconfig GUI over the internet using LabVIEW, I don't think there is any way of doing this.
Jeremy_B
Message 8 of 8
(3,804 Views)
