Motion assistant: Cannot convert to Labview diagram
I would like to ask for help on problem:  the file generation from Motion assistant to Labview
Background:
1.  Use Motion assistant to generate 2 or 3 steps of motion.
2.  Inside Motion assistant, Use Tools>>Generate Code>>LabView Diagram.
Result:
After I doing this, the LabView file is generated.  But, it is a file containing a few control switch (without any other key components to produce the motion control function).
Thus, what is the problem behind?
James
(2,733 Views)
Good morning James,
This post appears to be a duplicate of the following thread:
http://forums.ni.com/ni/board/message?board.id=240&message.id=3878
Please refer to this thread for the solution.  If am incorrect, please post back and I will do my best to answer your questions.
Respectfully,
(2,724 Views)
