MotorWay dll
I have a problem with MotorWay for the Motor-Bee with LabView 8.2. I used Tools»Import»Shared Library (.dll) with mt.h and mtb.dll and created a library with 3 Vi’s. Unfortunately if I start a Vi, I get a message that LabView must be closed.
(4,425 Views)
Can you provide the header (.h) file that came with the library, as well as any documentation for the functions you are trying to call?  Without that there is no way to know whether you're calling the DLL correctly.
(4,401 Views)
Thank you for the answer
mt.h
// Header file for use with mtb.dll
typedef bool    (*Type_InitMotoBee)();
typedef bool    (*Type_SetMotors)(int on1, int speed1, int on2, int speed2, int on3, int speed3, int on4, int speed4, int servo);
typedef void    (*Type_Digital_IO)(int *inputs, int outputs);
bool    InitMotoBee(void);
bool    SetMotors(int on1, int speed1, int on2, int speed2, int on3, int speed3, int on4, int speed4);
void    Digital_IO(int *inputs, int outputs);
(4,394 Views)
Have you tried playing around with the settings a little? I noticed, that in the field "library name or path", the file ending is .* instead of .dll. Since you could select the functions this shouldn't be the problem, but I'd change that. you might as well try other options for the calling convention.
I don't suppose I could fully reproduce your problem without your hardware, could I?
Remember Cunningham's Law
(4,392 Views)
I created mtb.lvlib with the help of Tools»Import»Shared Library (.dll). That’s why there is *mtb instead of dll. Then I created the same three Vi’s with library node and connected mtb.dll. Init Moto Bee did nothing. If I start Set Motors.vi or start Digital IO.vi, LabView crashes.
I work with WindowsXP and LabView 8.2
Here is a lvlog:
#Date: Di, 13. Sep 2011 15:19:32
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.2
#AppKind: FDS
#AppModDate: 08/19/2006 19:22 GMT
.\manager\ThEvent.cpp(152) : DAbort:
$Id: //labview/branches/Europa/dev/source/manager/ThEvent.cpp#4 $
0x00C5C053 - LabVIEW <unknown> + 0
0x00C7C7CF - LabVIEW <unknown> + 0
0x081DCA2E - <unknown> <unknown> + 0
0x08350C74 - <unknown> <unknown> + 0
0xA000C4BB - <unknown> <unknown> + 0
(4,385 Views)
Accepted by topic author Ludmila57
Have you seen this post?  It's about "StepperBee" rather than "MotoBee" but appears to be the same issue.  Try modifying your header file (after saving a backup copy) so that it reads:
int    InitMotoBee();
int    SetMotors(int on1, int speed1, int on2, int speed2, int on3, int speed3, int on4, int speed4);
 Then re-run the DLL import wizard and see if it works.  It seems to have solved the problem for the StepperBee user.
(4,374 Views)
Thank you. It works
(4,363 Views)
