Mouse Pointer on Table
Hi Vaibhav,
I wasnt able to run your code bcoz its compiled in LV8.6 and i am using LV8.5.
Could you pls save in 8.5 format and resend it?
Ritesh
Message 11 of 17
(2,004 Views)
Help Plss!!
Message 12 of 17
(1,989 Views)
Hey Guys,
 this thing is really driving me crazy now. I have been trying to solve my problem since last 2 days .. have tried lots pf approaches but still now Success.
Could anyone pls give a suggestion of how to solve it or just let me know if its possible at all or not ?
Ritesh
Message 13 of 17
(1,981 Views)
As no one is coming up with any solution or suggestion, should i believe that its not possible at all ?
Ritesh
Message 14 of 17
(1,970 Views)
Hi Ritesh,
sorry for the late reply. yesterday was a holiday so couldnt check the forum.
here is the VI in LabVIEW 8.5.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
Message 15 of 17
(1,959 Views)
HI Rithesh
          I got the solution.Just make a change to the example vi which i had sent.Add an Table Control -Value change event and create a table control disable property.
Hope this solves your problem.
Message 16 of 17
(1,945 Views)
Hi Geetha,
I tried your solution.
problem is you are disabling the table at the time of execution. due to which i am not able to see the short cut menu(basically shortcut menu is disabled with the table).
only if the table is enabled, i am able to see the short cut menu.
same is the problem with vaibhav's code.
Solution could be:
On right click, the table should be enabled and the menu should pop up. These two things should happen simultaneously or just one after the other.
But i am just not sure if its possible in LV.
Ritesh
Message 17 of 17
(1,932 Views)
