08-13-2019 09:40 AM
though this is an old post, I have found the solution for this:
It depends on the mouse settings in Windows itself. In Windows 10 the setting 'Scroll inactive windows when I hover over them' is per default switched on. If you switch this setting off, you can scroll again through case structure dropdown menus.
See also this NI KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fzh8SAA&l=en-US
I hope this information still helps somebody.
Best,
Kilian
09-16-2020 03:06 AM
thank you for this, your hint has helped to solve the problem "inside" LabVIEW. But however, I noticed just now, when I click windows 10 start button, I cant scroll down to go to any apps which not visible. Maybe NI needs to fix this issue?
