Mouse down event
Is there anyway I can keep the control properties as shown in the image attached if I add another event to the same event structure case?
I currently have an event structure case configured to execute on a mousedown event on a multi column listbox and would like to add a dynamic event to this case also yet keeping hold on the properties show in the image attached..
Strokes
(5,895 Views)
Is it not just a case (pun not intended) of right-clicking the event structure and selecting Show Dynamic Event Terminals?
(5,882 Views)
I understand how to create, register and generate dynamic events but when I add the dynamic event to the event structure it changes (naturally enough) the "CtlRef, Coords,Button" properties to other ones like "time, type, source" etc...
(5,877 Views)
Accepted by topic author Strokes
Strokes,
Yep, this is a minor annoyance with the Event Strucure. Even trying to "duplicate" the current event structure (and picking the same type of event) will cause the new case to have different dynamic terminals, or at best, the same ones you wanted from the duplicated case plus some others.
Richard
(5,860 Views)
@broken Arrow wrote:
Strokes,
I thought as much, thanks for clarifying... Looks like I'll have to find a workaround..
(5,853 Views)
It might seem obvious to some, but you can L-click any of the terminals to select a different one for that location.  From reading the thread, it just sounded like this was being overlooked (unless we're talking about duplicating tens or hundreds of cases in which case it could become quite tedious).
Never say "Oops." Always say "Ah, interesting!"
(5,845 Views)
The problem is that the terminals change when you add new events to the same event case...
(5,816 Views)
