Mousepen Genius
Does anyone know access to data of a Genius Mouse Pen?, I have tried with the block "Acquire Input Data", and this returns me the position coordinates x and "y", I also returned the pressure, but a Boolean value, I need the pressure to an integer value between 0 and 1024, but apparently the block will not let me, also tried to access the block and change the dll, but I don't know how it works.
I hope someone can help me. Thanks
(3,098 Views)
What kind of communication can this device make? USB? Serial?
What exactly do you want to control or check on this device?
How are you doing this now?
Thanks.
Best Regards.
Luciano Borges
Test Development Engineer
(3,063 Views)
