Move Vi Front Panel window
I need to move a Vi on the primary display to a different position (simulating a user dragging it somewhere)
Basically I need to ensure that sub vi's open in a particular place, but Sub-Panels cannot be used (Another software package is in use that calls Vi's and doesn't support Sub-Panel usage)
I want the sub vi to open and on the first execution loop move to the position that is passed through inputs. Is this possible?
(5,224 Views)
Use a property node linked to the VI to get a reference to the Front Panel and then another property node to set the panel's position.
(5,213 Views)
If it is always going to be the same place, go to VI Properties (Ctrl+I) on the subVI, choose Window Run-Time Position from Category, and set the position.
If you are going to programmatically choose the position, you can use a property node. There is a document here:
How Can I Programmatically Move My Front Panel to Desired Position in LabVIEW?
Ian
LabVIEW since 2012
(5,210 Views)
