Move or delete a file after a time period
How would such a program look that the user specifies the length of time that the file should be moved or deleted after or if a file size goes over a certain limit?
LabVIEW 2013
I have not lost my mind, it's backed up on a disk somewhere
Message 1 of 8
(3,522 Views)
While loop that periodically checks the file size and modified date (File/Directory Info function should do it).  If it goes higher in size and elapsed time, delete or move and quit.  I would use a wait of something like 500ms.  Also allow a way for the user to stop the loop.
Message 2 of 8
(3,511 Views)
Thanks for your reply,
Would it be possible to see a simple VI example of this?
Message 3 of 8
(3,507 Views)
Something like this
Message 4 of 8
(3,498 Views)
How would the user choose between moving or deleting the file after that time period ?
Message 5 of 8
(3,479 Views)
Boolean switch.  Enum.  The enum would probably be the better way since it is more self documenting and easier for the user to see what is happening.
Message 6 of 8
(3,473 Views)
How would the enum work if the greater than function is already wired to the case selector?
Message 7 of 8
(3,468 Views)
You have another case structure inside of the current case structure.
Message 8 of 8
(3,463 Views)
