Move signal on X-axis using a Scroll Bar
I have multiple signals on my graph and I want to shift these signals on X-axis. How could I move one of the two signals I chose to the right or left on x axis by using a scroll bar?
I'm using Labview 2009 SP1
Yasemin Barutçu
Electrical And Electronics Engineer
(3,098 Views)
You cannot use the graph x-scrollbar, because that is locked to the x-axis.
To shift one signal, you need to change the data. For example you could use a plain scrollbar from the numeric palette and increment or decrement the x-values of one of the signals according to the position. (Another possibility would be to use two different x-axes, one for each plot).
Here's a simple example to shift the red data. (LV 2011SP1). Modify as needed.
(3,094 Views)
Yes, this is what I mentioned. Thank you very much.
Yasemin Barutçu
(3,088 Views)
Btw, you seem to link to an image that is broken. It it part of your signature?
(3,084 Views)
Yes it was. I'll change it 😉
Yasemin Barutçu
(3,081 Views)
