Moving Hidden Controls on the Front Panel
I have hidden several controls on the front panel of my project.  I now want to simply move them so that when they appear, they show up in the correct place.  To access these hidden controls I navigate to the terminal of the hidden control in the block diagram and double click.  This takes me to the outline of the hidden control on the front panel.  If I try to simple drag this outline to a different place, the outline goes away and the hidden control is in the same spot.  I thought I could get around this by hitting unhiding the control, moving it, and then hiding it again.  However, when I right click on the outline of the hidden control on the Front Panel, there is no Show Control option only hide control.  See picture below:
Can anyone advise me on how to unhide these controls?
(3,703 Views)
right-click the terminal and select "show control".
(now go and also vote for this idea :D)
(3,702 Views)
I don't see it there either.
(3,685 Views)
You are clicking a property node(or similar). You need to click the actual terminal. To find it, right-click the node and do a find...terminal.
(If the control is inside a cluster, you need a few more steps)
(3,678 Views)
Ok, that worked.  Thanks for your help!
(3,671 Views)
