Moving Mouse using Labview
Dear Experts,
I have a project trying to use Muscle signal to move a mouse cursor on computer screen. Basically, if the signal is positive, it moves to the right, and if it is negative it moves the cursor to the left.
I've seen a friend did it before way back, but don't remember how. I've been spending a lot of time trying stuffs, but none works.
It will be nice if someone can post a simple example or give me tips on how to do it
Thanks!
Message 1 of 9
(24,689 Views)
Accepted by topic author MrCoolMan
Moving the mouse on the cursor can be done using operating system calls. On Windows you can use the Windows API, and examples of doing this have been posted before, though you can see the attached VI.
The other part of this is how are you gettting the signal? Do you have some sort of DAQ hardware?
Message 2 of 9
(24,681 Views)
Do a search for "SetCursorPos". You should find some examples which use this Windows API function to control the cursor's position.
___________________
Try to take over the world!
Message 3 of 9
(24,679 Views)
You can also find VI's for EMG processing and analysis in our free NI Biomedical Starter Kit.  More information can be found on our Biomedical User Group at www.ni.com/biomedusers
Message 4 of 9
(24,667 Views)
Another point is that it may be better to move something other than the cursor, such as an element on a graph or a control. This can allow you to create a much nicer UI.
___________________
Message 5 of 9
(24,649 Views)
Don't give the mouse cursor the functionality of clicking, it may just "Try to take over the world!" Or at least your PC.
-AK2DM
Message 6 of 9
(24,622 Views)
Thanks. It works!
Message 7 of 9
(24,491 Views)
What if I also wanted to press a button?
Message 8 of 9
(21,301 Views)
Message 9 of 9
(21,281 Views)
