Moving Programmatically Multicolumn Listbox Scrollbars
Hello:
I have a little problem with the Multicolumn Listbox and I hope somebody around here can help me.
I have a Multicolumn Listbox with few rows visible, let's say 4. Then I fill the Multicolumn Listbox with many elements, for example 20, and scroll down to see the last element. Then I "re-fill" the Multicolumn Listbox with few elements, let's say 3, they are not visible, so the user manually has to scroll up to see them.
How can I programmatically move the vertical scrollbar to the top when I "re-fill" the Multicolumn Listbox?
I've looked for a Property or something to do so, but haven't found it yet.
See attached VI.
Any help is appreciated.
Robst.
Robst - CLD
Using LabVIEW since version 7.0
(4,035 Views)
You want the "Top Left Visible Cell" property.
(4,024 Views)
Thanks Matt W, it works perfectly, I didn't see that property Smiley Tongue.
Thanks a lot.
Robst
Robst - CLD
(4,017 Views)
