Moving a LabVIEW Project to Another Computer
Hi All,
I have been trying to move a LabView project from my PC to one of my colleagues PC. I tried to make a zip and sent it packaged , but unfortunately on my colleagues PC it doesn't open fully. I use few addons that was installed through VIPM , even after downloading the same addons on the other PC through VIPM it shows as it is missing some .dlls ( all the drivers have been installed too ).
does anyone of you know what could be happening here ?
Thank you
(2,037 Views)
Hi Thili,
You forgot to install all needed modules/toolkits…
It really would help to show a error message box to identify the missing software components!
You should use a SCC tool (like SVN or GIT) to synchronize code between computers in your department!
(2,028 Views)
I made sure I installed all the necessary drivers and toolkits in the target computer , same as I have in my PC. I get this window where it tries to look for this specific .dll , but it's one of the drivers.
(2,014 Views)
That's a FTDI chip driver.
D2XX Drivers - FTDI (ftdichip.com)
Qestit Systems
Certified-LabVIEW-Developer
(2,003 Views)
Hi Thili,
That FTD*.dll doesn't belong to NI installation (IMHO), but comes with a driver that uses some interfaces with FTDI ICs.
You need to install that driver on the other computer…
(Atleast with my LV2019 installation there is no "C:\programs\NI\" folder, and so there is no "\LVAddons\nivisa\1\resource" subfolder!)
(2,001 Views)
