Moving average of 2d array.
hello , I need someone to help me to find the average of the 2d-array in my code that attached with my quistion.
(3,481 Views)
Your code makes not a lot of sense.
In the first FOR loop you create a 2D array of sections, but since the sections depend on the data, they most likely have variable length. LabVIEW does not support ragged arrays directly. The second FOR loop just repeats the same thing as fast as the computer allows, and thus does not make a lot of sense either.
Can you explain in words how the array should be processed? I am sure this can be done with 10% of the current code.
(3,452 Views)
thank you for reply ..
actually the second for loop is wrong from me .. I need to calculate the average of the output array from the first for loop and then apply filter to remove some noise appears in the signal
please help me if you can ..
(3,437 Views)
Accepted by topic author Sanad995
If you want to average all sections starting with each local minimum, you could do something as attached. (very rough draft, probably needs a tweak here and there, so modify as needed)
Averaging already removes noise, so I am not sure what other filtering you have in mind.
(3,424 Views)
thank you so much for your help
(3,419 Views)
