Moving camera 3D picture control
Hi
How do I control the camera with variables (x,y,z) in my 3d picture control box- my functionallity is to follow a box that is moving.
For now I just want to figure out how to get a camera to move without moving it manually with with a mouse.
Thanks in advance
(3,556 Views)
Are you doing some sort of image tracking? You might want to explain a little bit more about what hardware you are using and or post your current vi. Without knowing details of what exactly you are doing and the hardware you are using all I can suggest is,  saving the start position (x,y) of object image, get some cheap distance sensor and get the (z) and then in a loop keep camparing if the current location is different than previous. if there is change in any coordinate, use the delta (change in cordinates) and use some servo motor to change the camara angle based upon the change that you just measured.
Kudos are (always) welcome for the good post. 🙂
(3,550 Views)
Hi everything I'm doing is virtual. So I created a virtual 3d cube and as it moves I want my camera to move as well. Think of it as a 3d simulator . I managed to get the cube moving but I can only move the virtual camera in perspective , othogonal etc using the mouse. I want the camera to move in the virtual world like you would in a 3d game
(3,544 Views)
Use the "image view matrix" property.
Google that term to learn how to use it since it is a OpenGL property.
Ben
(3,532 Views)
@Ben wrote:
Use the "image model view matrix" property.
Ben
(3,526 Views)
